Subject: Azura from Morphworld won't open - any ideas?
archrendr opened this issue on Dec 08, 2002 ยท 11 posts
archrendr posted Sun, 08 December 2002 at 7:53 PM
Hi... I dl'ed Morphworld's free Azura and Eve along with the tutorial and the 'loader' thingi. Appears to have installed properly but will not open. The error msg is: CANNOT OPEN RESOURCE FILERUNTIMEGEOMETRIESP4 NUDE WOMANAZURA V4.OBJ. The next msg is: YOU ARE OUT OF MEMORY, BLA BLA BLA ALLOCATE MORE TO POSER. I have 384mg of PC133 on Win 98SE, and that oughtta do it.... Any suggestions whats going on? Many thanks and how (anyway) would I allocate more memory? Thanks again, Archrendr
wadams9 posted Sun, 08 December 2002 at 8:19 PM
Nothing wrong with your memory, that's just something Poser often says when it's upset. Is there an "Azura V4.obj" in your runtime/geometries/p4 nude woman/ directory? That gap in the file name worries me.
As it happens, I just recently downloaded Azura and Eve myself and have not installed them. I'll do so and get back to you if it teaches me anything.
Bill
archrendr posted Sun, 08 December 2002 at 8:46 PM
Thank you, very kind!!! No there is no azura.obj...only an azura.pcf. Whatever that is. I checked at the root of Meta creation and all deeper files and no azure.obj lurking anywhere. Ill go back to morphworld to make sre I got all the dl's. Again thanks archrendr
tasquah posted Sun, 08 December 2002 at 8:47 PM
You need to convert this first "Azura.pcf" if you already havent. And my poser does the same thing when it goes into a search mode and cant find what its looking for . It will slowly eat up any resourses available looking for stuff.
tasquah posted Sun, 08 December 2002 at 8:50 PM
its done with a program called " Object Mover " in the free section .
Tashar59 posted Sun, 08 December 2002 at 8:51 PM
If i recall, you need to decode object file. I think Azura is in .pcf. Once converted make sure you have the files in geometries in the right place. It's been awhile sence I used her. Hope this helps. Tashar 59
Tashar59 posted Sun, 08 December 2002 at 8:52 PM
tasquah- you beat me to the answer. Tashar 59
wadams9 posted Sun, 08 December 2002 at 8:54 PM
Yeah, you've got to use Objaction Mover to convert the .pcf seedfile.
Did you find the "how to install Azura" file at Morphworld? It's coming to back to me that maybe you get a no-file-found when you try to download those instructions. If so, go back and get the "how to install Eve" file instead -- it will tell you what you need to know about decoding the .pcf.
(Objaction Mover can be downloaded free here at 'rosity. Don't worry, everything should work, you just skipped a step.)
Bill
tasquah posted Sun, 08 December 2002 at 9:01 PM
sorry i will type slower next time been drinking way to much starbucks coffee today. I use it for a blur tool on Photoshop .
BluesPadawan posted Sun, 08 December 2002 at 9:24 PM
For a lot of newbies doing something other than loading the files into the right directories is a major event. Isn't there some standardization that can be done? ....still looking for files that disappeared into Poser Never World. :)
archrendr posted Sun, 08 December 2002 at 10:31 PM
I found it....I only used half the options in the OBJACTION MOVER. Thank you all for the help - especially the tip for blurring images with starbucks coffee. Ill try thet next.
