SolubleHamster opened this issue on Dec 10, 2002 ยท 9 posts
SolubleHamster posted Tue, 10 December 2002 at 4:32 AM
Soluble Hamster
The one, the only, dissolvable rodent.
Little_Dragon posted Tue, 10 December 2002 at 5:29 AM
Wasnt expecting the 4th steph .... * chuckle * That's how corner mirrors work, y'know. Two reflective surfaces, three reflections. When I was experimenting with faked reflections in P4, I had to put in a little more effort and add that reflected reflection, also. Displacement shouldn't slow things down much, but reflections and dynamic hair can be killer. Cheer up, 5GHz machines will probably be available by this time next year.
Spit posted Tue, 10 December 2002 at 6:02 AM
But it's just default lights, default render settings, and smaller. It would take longer if I used premium settings. But still, two hours seems like an awfully long time.
Little_Dragon posted Tue, 10 December 2002 at 7:25 AM
I just ran my own timed test in Poser 5, using a similar scene and setup. It rendered in a little under three minutes in Production Mode with shadows, and I don't exactly have the most robust system on the planet.
Still using a Pentium 3-850MHz rig, 128MB RAM, Win98FE (for now).
SolubleHamster posted Tue, 10 December 2002 at 8:41 AM
O_o Looks like i might have to bother d/l the patches after all. Havent done it so far cos I have had NO problems with P5 right out of the box. If it aint broke don't fix it :) Soluble Hamster The one, the only, dissolvable rodent.
zechs posted Tue, 10 December 2002 at 10:44 AM
LOL! God, yes get the patches...ALL OF THEM. The speed increases are tremendous from the boxed version. It's pretty reasonable now (though still not exactly fast)
DefaultGuy posted Tue, 10 December 2002 at 12:48 PM
A suggestion to all above, If you are using Hi Res texures, I'd recommend turning off the FireFly render option, Use texture filtering. This speeds up rendering times immensely. Buried deep in the following thread are several tips I provided over the weekend on setting up render options. Have at it and I hope these tips help you out with future rendering, -Brian
DefaultGuy posted Tue, 10 December 2002 at 12:49 PM
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=991590 ...forgot to add the thread. Must be getting senile, -DefaultGuy
praxis22 posted Tue, 10 December 2002 at 5:00 PM
Groovy nick there SH :)
