I just noticed this. If you are rendering something and are using the select render area. And are rendering on broadcast for some unknown reason Vue renders whatever who knows where it's getting the picture from cause like whole trees are missing in the render. Bizzare. I'm trying to check my leaves here and noticed vue just not rendering properly in broadcast to the screen. This is a new Vue BTW cause for some reason I killed the old one. Some of the Vue buttons got munched somehow and if you put the mouse on them Vue would crash so I uninstalled it and reinstalled it and applied the 4.11 patch then I noticed this bizzare behavor. This took forever to render BTW to show you what it's doing. It's on drugs or something cause like this is not what it is suppost to look like. This is the exact same spot rendered in Final, Broadcast and User... It's just a little piece using the select render area tool rendered to full sized screen. I just selected a little spot over on tree to check the leaves. Oh and I did try discarding the render area and reselecting it several times. It never made a diference. Anyone else notice the wierdness?
