Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12413&Form.ShowMessage=888765
Again, use a new layer, set the layer to screen, paint the highlights using the airbrush. Play with duplicating the layer and setting it to overlay. However, a better method is to make the glow at render time using a colored spotlight. See my jedi pic at the attached thread. The glow on the character was rendered in poser. The glow on the wall was done using the above method..
Hmm, I was thinking of a different technique perhaps to have some ambient red light reflecting off her body suit for added realism. You could experiment with a red spot light in Poser maybe, or in Photoshop, experiment with the dodge tool on the red channel at varying exposures...thats how I'd do it anyways...or perhaps use another layer of red where you want the glow at varying transparencies...then use your lighting effects and diffuse glow for added realism. MO only Evo
The blade produces a halo glowing effect and can "pulsate" when animated. No textures are used so the color can be easily changed in the materials menu.
I'm hoping to put together an entire package of various blades, blasts and laser beams plus scripts to "pulsate" them for animations.
-=JFStan=-
Photoshop Lightsabre Tutorials
http://www.jmort.com/lightsaber.htm
http://wynd.teamanime2k.org/tutorial_lightsaber.htm
Attached Link: http://www.kuroyumes-developmentzone.com/~jfstan/sabre_test.avi
Thanks Nether... Here's a link to a very short animation which demonstrates the pulsating glow of my lightsabre blades (DivX format).-=JFStan=-
