Mon, Jan 27, 12:52 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Subject: Clothing Quandry
lwanmtr ( ) posted Mon, 16 December 2002 at 2:23 PM ยท edited Mon, 27 January 2025 at 12:29 PM
I am in the process of making an outfit (ensemble) for Vicky and have some questions..... First, is it best to keep the geometry relatively the same as the body? The peices I have made have a higher geometry count, but the parts are in the same locations. Second..Gloves...I have been having problems getting the gloves to work right....How do I keep it so that when I make a fist, the fingers dont pop through..I have made sure that the geomteries dont cross (and even have a little room to spare). Thanx.
thgeisel ( ) posted Mon, 16 December 2002 at 2:54 PM
only one tip for gloves,make the fingers of the hand invisible
thip ( ) posted Tue, 17 December 2002 at 5:09 AM
Unless you have very fine-tuned spherical falloff zones, it is very hard to make the fingers move without interfering with each other, adn/or the hand. One solution you might want to consider is setting up each finger with an extra group, such as a knuckle, to "isolate" the fingers from the hand, more or less like the buttock groups on figure "isolate" the thighs from the hips to minimize distortion. That way, you can work without spherical falloff zones entirely. All hand poses only involve settings for the "known" finger parts, so the knuckles will simply be "along for the ride", doing their bit to make sure the first finger joints don't distort the hand. Give it a try if you think it's a workable idea. Good luck.
lwanmtr ( ) posted Tue, 17 December 2002 at 1:30 PM
Thanx, I'll give it a try.
