Thu, Nov 14, 12:32 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Where can I find a cr2 editor or help
Justice ( ) posted Mon, 03 April 2000 at 7:42 PM · edited Fri, 09 August 2024 at 10:52 PM
I'm trying to modify the existing cat model included in poser 3 to make the tail less chunky. I subdevided the nodes of the old tail in ray dream and re-imported the cat into poser useing a re-created .phi. Unfortunetly it seems none of the custom morph targets I created for the cat will work now. I was hoping that I could modify the original cr2 file to reference the new tail, but this would require an editing utility if it is even possable. Does anyone know where I can get such a thing, or do you have any better ideas on how this could be accomplished. PLEASE HELP!!!!
Kevin ( ) posted Wed, 05 April 2000 at 9:49 PM
There is a utility called cr2edit. It is in the utility section, called "Poser Library File Editor". Take a look at that. http://www.renderosity.com/download.ez?uploadid=1521
Oliver S ( ) posted Thu, 20 April 2000 at 3:22 PM
Or you could try BBEdit Lite 4.0, which will open the .cr2 file allowing you to copy and paste the morph geometries from one to another. It also saves back in a Poser 3 format. I think it came free with the Poser 3 CD - certainly on the Poser 4 one
