Well the first one I can help you with, alot of the pictures you see in the gallery were done with Poser 4, it will say which one it is, Poser 5 has some nice ones too. As far as the people coming out of the water you can do that with Poser 5 but I am assuming they used another software like Vue d'Esprit or Bryce and rendered there, of course you should read the bottom of the picture it usually says. I am not to sure about your second question though. Poser 4 does a very nice rendering pictures. Sharen
"when i tried to put a basic pic into adobe to print off it will only go up to a certain size and then pixelates 10x8 is out of the question" Click RENDER>then RENDER OPTIONS>click NEW WINDOW (allows larger renders), change resolution to 300 or better (if your mach can handle it). The size and resolution will be limited by your memory. 72 pixels per inch is usually for the web. 300 pixels per inch is for print. the higher the resolution, the larger you can make the image before pixelation.
For Q1 - There are spectacular renders done in each version of Poser. The realism is from using professional quality textures (some are free, many are commercial if you're not good at texturing), good lighting (some light sets are available for free and some for purchase if you need lighting help) and lots of practice. There are a bunch of tutorials out there to help you get more realistic results as well. (I have some tutorials on my site, including making more realistic faces and poses.) You can fake backgrounds in Poser using a variety of tricks. (DAZ Cyclorama, 3dModelz' 3DWorldz, and Runtime DNA Infinity Cove are a few examples.) P5 can somewhat create water, but most people use some postwork in Photoshop or PSP to make it look more realistic - water beads on skin, etc. For Q2 - you probably need to render the picture in a larger size. You can Render to New Window and specify a larger pixel size. (I'm not at a computer with Poser on it, so I can't give the exact path, but if you look a little, you should be able to find it.) Once the picture renders, you click on the new screen to close it and Poser will offer to save the picture. (I mention this because the first time I rendered to a new window I couldn't figure out how to save the picture and freaked out.) Cheers!
Attached Link: http://www.gimp.org/
If you don't have PhotoShop or PaintShop, you can get gimp which does the same thing for your post work and it's FREE. You need a program that does layers to get the full effect your looking for. Tashar 59This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
i am playing about with poser 4 but im new to this, its a 2 part question. the fantastic pics im seeing on this site with great faces and bodies is that done on with poser 4 or do you need 5 and how do you get great backgrounds ie people coming out of water etc. and 2 when i tried to put a basic pic into adobe to print off it will only go up to a certain size and then pixelates 10x8 is out of the question so if anyone can help cheers delboyo
