Thu, Feb 13, 1:06 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 12 7:20 pm)
Carrara Free Stuff here.
Subject: WIP
aeryk71 ( ) posted Wed, 19 April 2000 at 9:26 PM · edited Sat, 08 February 2025 at 9:45 PM
Planks, TreeDruid, and Shades of Reality. Got to get the floor, and tree and walls just right... Aeryk
ClintH ( ) posted Thu, 20 April 2000 at 7:54 PM
Sweet! Nice work! Clint
Clint Hawkins
(Zakk Wylde (2007))
aeryk71 ( ) posted Thu, 20 April 2000 at 10:11 PM
Thanks Clint! Contest did not go my way, but that is ok. Will keep trying :-) Aeryk
bretford ( ) posted Fri, 21 April 2000 at 12:07 AM
Aeryk, I've got a few suggestions on the planks. I like how you have the wood grain going opposite the planks direction - its a really good idea. I would add the plank shader to your bump channel, then decrease the width in the color channel. Also, if you used lumber yard for the wood (I can't tell, if you're not, you should try it) if you fill in the plank info on the wood shader, it will seed each plank differently, making them look like they came from different parts of a tree. Also, you might want to add just a tinch of value variation in the wood shader, and a tinch of reflection to the floor, the tree looks great. I think the pot could benefit from some adornment - say metal rings around the protrusions. Try copying your model, editing the copy (make sure you choose 'create new master'). If you pull the ridges out just a little, and sink the valleys in, you should be able to come up with something like that, if you think it'd look good. Brian P. Retford Carrara Extensions www.losthorizonsoftware.com
