I had the same thing happen, ask for the bum file and then poser 4 crashes instead of canceling. After this error I kept getting can't open Vic3.obj and couldnt figure out what was wrong, then I remembered to try and delete the .rsr in the Geometries folder and then I just went through using edit pad and took that bum reference out of the mat pose files and replaced them with NO_MAP. If I need to do a highly detailed close up I can apply the bum manually. I hate those darn things. After this she worked great I think she is fantastic, very versatle and she poses so wonderfully. The injection poses worked better in poser 4 than 5 but I had her working in both quite well applying the pose/morphs one at a time which is my personal preference anyway. Now I cant wait for Mike 3 :)
Quick Clarification, I should have known better and converted the jpg first as it said in the readme but in my haste to open her forgot and then she wouldnt open. I prefer just removing those references to the bum file but I know many would not prefer to do it that way since it must be manually, the easiest way is converting them before opening her.
Hey rockets and anyone else who had this problem, whatever you do, DON'T FEEL DUMB! This forum is at its best when people can help each other. It seems that lots of P4 users go through this with various models. It was a learning experience for me with the Millennium Dragon. LaurieA and Dave71.s suggestions are perfect. One more thing, though; If anyone actually goes through this process and assigns the .jpg bump maps to the model in P4, it's possible that the MAT pose file will load the .jpgs, not the .bums, every time after that, even after you convert the files in the Materials Editor, UNLESS you use a text editor (e.g. Windows' Notepad) to open the MAT pose file and change the extension of all the bump map .jpg assignments to .bum. This is easily aided with Notepad's "find" feature. Search on the word "bump" and you can quickly click through the various references. (Skip the bump strength references.)
Yeah the bump map think is a pet peeve of mine in Poser too. So anoying. Sorry it bugged ya.
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
xo... why don't you just use the txt editors search and replace on ".bum" to ".jpg."? then it won't hit the bump_strenth and whatnots. p4 can load jpgs or greyscale whatevers into the bump channel if you change the cr2/pz2 files to do that. they don't work exactly the same as the bum files, but they usually give okay results. if your figure comes out with weird black soot all over him/her, then you need to use the bums, not the jpgs. :)
First, thanks so much for the new V3...she looks wonderful! I bought the high res pkg. and just tried to apply the Mat pose textures to V3. I run Poser4 (no propack) and Poser keeps asking me for the textures when I click on any of the mat pose thumbnails. It goes down the list and then will start asking for the same texture all over again and then crashes. Were the textures ever tested on plain old Poser4? I've had this problem with other Daz textures as well. Sorry if this sounds like I'm whining...I just think Daz should be aware of the problem and maybe fix it. :-)
My idea of rebooting is kicking somebody in the butt twice!
