Fri, Jan 10, 11:43 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: V3 geometry bug? (Nudity)
Staby ( ) posted Sun, 22 December 2002 at 7:39 AM · edited Sat, 04 January 2025 at 5:03 AM
Hi, I read the various V3 related posts for a couple of days, but did not find any reference about this problem. I purchased Victoria 3 the first day and tested her for hours, injected morphs without problems and checked them all, without moving V3 from the default position and everything looked fine. Then i tried the V3 poses that come with the base set (the V3 Backturn pose in particular) I spotted what seemed inverted poligons in the hip region, but when did a close up it was worse. It look like the geometry breaks... Could you tell me if you have the same problem? I'm writing a note to DAZ and more info would be useful. BTW I purchased the stand alone version and not the upgrade, but I think the blMilWom_v3.obj is the same in the two installer. Here is a close up picture showing the problem. V3 Backturn pose, default lights, no morphs applied.
Same shot with DAZ global lighting set
Mazak ( ) posted Sun, 22 December 2002 at 8:07 AM
No problem here... Poser5 Vicky3 update. Mazak
Google+ Bodo Nittel
Staby ( ) posted Sun, 22 December 2002 at 8:11 AM
Thank you for the replay. So it is a problem only for the stand alone version?
Mazak ( ) posted Sun, 22 December 2002 at 8:13 AM
Have you the latest Poser patches?? This can cause the problem also. Mazak
Google+ Bodo Nittel
Staby ( ) posted Sun, 22 December 2002 at 8:23 AM
Yes I have the patch installed. Forgot to say I use it in Poser 4.03. Haven't tried it in P5 yet because I read it was difficult to loads all morphs.
thgeisel ( ) posted Sun, 22 December 2002 at 8:34 AM
With my viccy everything is alright and in the right place!!!AND DON`T TELL ME THERE IS ANYTHING WRONG WITH HER!! poser 5 and V3 upgrade.No gaps there
Chris ( ) posted Sun, 22 December 2002 at 8:55 AM
Have you turned "genitalia" on or off? If its off try to turn it on maybe thats the problem. Just a thought Chris
"It Is Useless To Resist!" - Darth Vader
Chris ( ) posted Sun, 22 December 2002 at 8:57 AM
btw ... full version and upgrade are the same ... upgrade only ckecks for a previous installation of Vicky 1 or Vicky 2. Chris
Staby ( ) posted Sun, 22 December 2002 at 9:18 AM
I tried V 3 in Poser 5 and it seem to have no problem there, but in Poser 4 it is like that. Turning "genitalia" on or off don't change anything.
Chris ( ) posted Sun, 22 December 2002 at 9:27 AM
V3 works in both P5 and P4. its weired ... have you tried to zero the joints? Sometimes that helps too. Chris
Staby ( ) posted Sun, 22 December 2002 at 3:51 PM
Thank all of you for the replay. I can't fix the problem in Poser 4, while in Poser 5 I get the same result of Mazak in post n.3 and it seem to work. It is weird indeed. I will need to contact DAZ about this. Thanks again
