Mon, Feb 3, 5:38 PM CST
Forum Moderators: Staff
Subject: How do I import Poser Textures into TrueSpace 4
pjanak ( ) posted Thu, 20 April 2000 at 4:41 PM · edited Sun, 26 January 2025 at 12:57 AM
I had seen a tutorial a long time ago but have since forgot and its not in the tutorials here. I need to know how I need to orient the uvmapping. While in TS 4. I tried many ways but I must be skipping something. Can someone please help
3DMark ( ) posted Fri, 21 April 2000 at 9:50 PM
Urrrr I have to convert the Poser OBJ or 3DS to COB then change the texture ti TGA or BMP if it is a TIF. This in in TS 3, JPG can be used if it is at least 24 bit color.....
pjanak ( ) posted Sat, 22 April 2000 at 12:35 AM
Yes I recently found out that even though TS understands object files its best to use a conversion utility to convert from obj to cob. I had one all along but never bothered simply because TS understands obj. I didn't realize that doing a conversion was the only way the the testures to fit right.
