Fri, Nov 22, 9:47 AM CST
Subject: mapping V3 to V3 prob
artbyphil ( ) posted Tue, 24 December 2002 at 7:35 AM · edited Sat, 05 October 2024 at 1:22 PM
Hi there Just had a go at the re-mapping of vic 3 to vic 2 I followed the instructions I found here. I did the obj file with no problems and then I did the cr2 editing in Notepad. I called the file Victoria 3-2uv.cr2 as in the instructions and all seems correct. However poser isnt seeing it and when I look in the folder its still being seen as a text document and not a cr2. what am I doing wrong here, do I have to save it differently? Im new to doing this type of thing and probably missing something obvious! cheers
VI_Knight ( ) posted Tue, 24 December 2002 at 7:43 AM
Check and make sure that you have the View Extensions property set in your folder options in your windows explorer. It may be appending the .txt to the end of the filename after you edited and renamed it. If that is the case then rename again and take the .txt from the end.
artbyphil ( ) posted Tue, 24 December 2002 at 7:48 AM
VI Knight that was the problem, didnt think of looking there. windows being too clever for its own good again! cheers
VI_Knight ( ) posted Tue, 24 December 2002 at 7:56 AM
Glad you got it fixed. Happy mapping.
rain ( ) posted Tue, 24 December 2002 at 1:12 PM
Where can I find the instructions, please?
PabloS ( ) posted Tue, 24 December 2002 at 3:21 PM
