'mac, the program isnt 100% user friendly. A person that doesnt know a cr2 would most likely have problems..however, one that knows a cr2 could use it to remove the few parts that it misses.' Sounds fine to me! I hate user-friendly programs and spend 50% of my time in cr2s anyway. I'd be up for it if you could make it available. mac
ok here's the link http://www.brycetech.com/stufftodelete/stripper.zip there are two files..the exe and a text file that dictates what is removed. the text file has some comments in it that you can look at for more specifics about the program. It also saves ALWAYS as a pz2 file because I figure its easier to fix a pz2 should you make a mistake with naming than it is if you overwrite a cr2. When you click "convert", you will be presented with two dialogs..the first one is the file you wish to open..the second is the name you wish to save the stripped file as. I use it all the time to make files a manageable size while I drink pepsi and watch tv :P its a bit rough, and not optimized for speed..but like I said, I do other things while it does the work. shhhh..dont tell anybody about the animation that plays while it works...lol btw, its visual basic and I am assuming you have the vb runtimes installed. If you get lots of errors, then you dont have everything installed. The most common file to be missing would be "scrrun.dll". have fun..Im sure it'll save some cr2 stripping headaches (it does for me :)) BT
