Tue, Feb 11, 6:24 PM CST
Subject: WIP Cub Scout uniform for PTboy
Rudolph_the_Reindeer ( ) posted Wed, 25 December 2002 at 10:12 PM · edited Sun, 09 February 2025 at 11:00 PM
Sweatshirt from PoserWorld - texture by ZME Shoes and socks from PoserWorld Cap and neckerchief by ZME Question... at the moment I have 6 seperate tex maps for the sweatshirt, 1 for each relevant figure part. How can/do I combine all maps into 1?
Niles ( ) posted Wed, 25 December 2002 at 11:29 PM
Looks good, kinda Harry Potter look. Not sure how to help you, but someone with better texturing skills can. Niles
TrekkieGrrrl ( ) posted Thu, 26 December 2002 at 4:40 AM
I'm not quite sure if this is what you want but you could make a MAT pose fot this. With the free MAT pose edit it's even easy to do. just save the figure as a character and use that new cr2 to make a MAT pose from (Not sure if it's the 100% correct way to do it, but that's how I do....)
steveshanks ( ) posted Thu, 26 December 2002 at 7:33 AM
Wow that brings back memories ;o)....we had red scarfs and i was seconder of white six ;o).you need sock tabs btw :o)..open the obj in uvmapper and select all, then tools, asign to material and either pick one or create a new one, save the template (be sure you make it the same size as your map) and then save the model.....close poser and delete the rsr sitting next to the obj (ignore that bit if you have PPP)and your good to go...Steve
Rudolph_the_Reindeer ( ) posted Thu, 26 December 2002 at 11:28 AM
steveshanks: look a little closer.. he has red sock tabs :) just don't show up too good at that angle
