Ok.. to use a morph, put them somewhere you can find them easily. Then load up Poser, select the part you want to morph (and it's got to line up.. if you downloaded a p4female head morph, you've got to have the p4female's head selected.) Then go to object>load morph target and a dialog will pop up. Click browse, find the file, OK, then give it a name where it says "shape 1" it helps if the name's descriptive. Click OK and the name should show up on the dials to the right. Click on the number next to the morphs name, type in 1, and hit enter. That should do it. Rosh
Another way that I think is a bit easier is to simply create your morph folder in your P4 directory. Then all you have to do is double-click on the part you want to morph, in the box that appears select "add morph target", (the box defaults to your poser directory :-) & follow the instructions from there.
I had to be seem to stupid. but I want to try and use some of the great morph files found here. but I don't know how to install & use them. I use poser 4 - windows version.. Please email yours replies to msamuels@optushome.com.au
" The Only Limit is your imagination "
