Mon, Jan 20, 3:57 PM CST
Forum Moderators: Staff
Subject: Sorting morphs
nandus ( ) posted Fri, 24 March 2000 at 2:01 PM · edited Sat, 17 August 2024 at 3:23 AM
As the number of morphs for some parts like the face is huge, everytime I add a new one it goes to the top of the list. This is quite inconvenient! Questions: 1- Is there a easy way for reordering morphs so they don't get mixed? I know about he hard ways! HE and Morph Manager doesn't seem to do that trick. 2- Is there a way to make the dials column wider to make more room for the dial's names? Nandus
techstuff ( ) posted Sun, 02 April 2000 at 9:04 PM
I found that by loading the cr2 into "Morph Manager" into both the left and right windows I was able to reorder the morphs. First delete all target morphs from the left window. Then copy the morphs from the right window in the desired order. Finally save the left window once you are sure it is as you like it. I would suggest that you save it with a slightly different file name at first so as not to overwrite the original cr2 file. If all works out, then replace the original cr2 file. I couldn't find an easier way to do it
techstuff ( ) posted Sun, 02 April 2000 at 9:06 PM
I should have mentioned that in copying the morphs do them in reverse order (ie., last one first).
nandus ( ) posted Mon, 03 April 2000 at 3:58 PM
Thanks Techstuff, that's they way I'm doing it now. It's a cumbersome method, one mistake and deleting all the morph's stack on top of it!
nandus ( ) posted Mon, 24 April 2000 at 12:33 AM
Thanks Codeman, I haven't tried that one yet.
