Forum Moderators: RedPhantom
This may actually be an opportunity. People have noticed that working the dials in Poser 5 longer transfers morph settings to that same figures clothing morphs. If we can figure out how to have "Controlled Cross-talk" I see that as an advantage. The ideal situation would be that if a figure is conformed it accepts cross talk. If that figure is independent it does not.
The method described by Rob works!! Obviously you should not inject the same morphs into two different Vicky 3 while they are in the same scene. By saving and deleting the first Vicky and then adding her again after injecting the morphs to the second Vicky you avoid this "new" version of crosstalk. Thanks Rob :-)
I'm too lazy most of the time to use Rob's Null Loader, or I just don't plan that far ahead, one thing I often do is just run the offending morphs in the second figure backward to remove the unwanted change. You can't use the FBMs (as the master figue is using it), but the individual morph dials can be turned back.
A trick I use is to save the null loader as the default figure (so when you start a new poser document, there is always a "millinium null" in scene. It does occassionally cause problems, but it can easily be deleted. I almost never use non-mil figs (though JBs enhanced posette might change that :) eric
We were told that crosstalk was cured in Poser 5, but obviously Victoria 3 has brought it back... Has anyone else noticed this? I made the following example to show the effect: 1. Loaded the first Vicky 3 2. Injected all full body morphs 3. Set the "Barbarian 1" morph to 1.0 4. Loaded the second Vicky 3 5. Injected all full body morphs to her After doing this, the morph applied to the first figure got transferred to the second one. No morph dials works on the second figure after the morph injection (they still work on the first one) Is there a way around this or do I have to dig up the old null loader again? :-(
