Under 2d texture, you next have to select "image map" before you can browse to the texture. Vicki 1 and 2 have a lot of different material groups (sodoes 3, but they are different), and without a MAT file you will have to apply the proper texture to each material. Most texture sets have, at a minimum, a body texture and a head texture; there may also be maps for bump and transparency. You need to look at your particular set of textures and determine which texture is which. The head texture you should assign to the SkinHead, eyebrows, eyelash, lips, nostril, tongue and teeth materials, as well as the eye materials. The skin texture gets applied to SkinBody, nipples, fingernails and toenails. I've probably forgotten some materials, but you should be able to figure out what goes where with the above info. Also, to make your life easier, you don't need to create a new node and browse for every material. For any node, be it a 2d texture or whatnot, you can right-click and copy it, and then go to the next material and paste it.
Hi Darkdemon -- just saw your other post, so I don't know if you are still following this thread or not. Posette, Vicki 1 and 2 together, and Vicki 3 are all different models, and take different maps. If it is Vicki 3 you are using, you need to use textures that specifically say they are for V3, UNLESS: You use UVMapper and the UVS files from Daz to remap her to match V2 (search in this forum -- there are some excellent step-by-steps on how to do this) or You apply the textures to the V3toV2 figure (whatever it is named), which should have been included in the install of your V3 purchase. Happy to answer any mroe questions you have -- hope this helps
Ok, I've downloaded alot of Eye textures and body textures for Poser 5. Now, how do I apply these since they dont appear in the menu to the right. I know it's such a newbie question but I'm really puzzled here. What button in the Material Room should I use? Or is it bad compatability? I don't know much about the program so no biggie words plz ;)
