Thu, Jan 30, 10:46 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 30 7:24 pm)
Subject: please help - postwork for rendering
karl231 ( ) posted Fri, 03 January 2003 at 6:27 AM ยท edited Thu, 30 January 2025 at 10:40 PM
Hi all!
when i render a scene to avi , antialias is selected, but
the result does not at all look antialiased.
there seems to be no way in poser to get a clear rendered avi, does anyone knows any postwork i could do with another prog?? thx
wgreenlee1 ( ) posted Fri, 03 January 2003 at 6:47 AM
If you can I would render frames instead....plus what codec did you use? That could be the problem.....
Ericroy ( ) posted Fri, 03 January 2003 at 10:43 AM
In poser, I always create full-frame, uncompressed, half resolution animations. The compression software slows the rendering process terribly and the result looks awful. When I get a good animation and it need a smaller file size, I use a different software to compress it (like RAD Video Tools http://www.radgametools.com/). I hope this helps, Ericroy
raven ( ) posted Fri, 03 January 2003 at 4:32 PM
Have you made sure you selected 'Use current render settings' in the animation options, it defaults to current display settings.
karl231 ( ) posted Tue, 14 January 2003 at 1:51 PM
thanks to all of you
