Mon, Dec 23, 12:22 PM CST
Subject: Table Saw (And some questions about conforming)
Kagato98 ( ) posted Sat, 04 January 2003 at 4:18 PM ยท edited Mon, 23 December 2024 at 12:08 PM
I just finished adding joints to this today. So now everthing rotates the way it should :D . My question is this: Right now, I have this set up specifically for Judy. I have a pose that fits it exactly; however, when I saved the pose, it simply saved the character pose, not the world transitions. This means that I have to load the table, Judi, and the pose, and then rotate Judi's body by -90 degrees and move her up .2 in the yAxis. Why is this? And a second question is this: I want Judy to be able to conform to this table. Would it be easyiest to conform her, and THEN apply the pose to get her to fit the shackles? And a third question...I've never created a conforming figure. What would be the best tutorial to look at for this?
PhilC ( ) posted Sat, 04 January 2003 at 4:39 PM
To have it conform you need to create the model in such a way that when its OBJ is imported into Poser it will correctly align to the figure when it is at its zero pose/zero translation. In this instance the table would have to be modeled upright not laying flat. Next I suggest that you name the bed group "hip" and set its joint center to match the center point of Judy's hip.
As for a conforming tutorial, click on the link above. There are many there. Details of my one are on my site.
Kagato98 ( ) posted Sat, 04 January 2003 at 4:43 PM
Hmm...I have a feeling I should have read some conforming tutorials before-hand ;) . What about the pose then? Why doesn't it save world transitions?
PhilC ( ) posted Sat, 04 January 2003 at 4:56 PM
Try positioning the figure by translating and rotating the hip rather than the body. I think that will be saved to the Pose file.
Little_Dragon ( ) posted Sat, 04 January 2003 at 5:54 PM
You can manually copy-and-paste the world transitions from a CR2 or PZ3 to the pose file, if you need them. I use MAT Pose Edit, myself.
tasquah ( ) posted Sat, 04 January 2003 at 6:15 PM
Attached Link: http://www.3dpmr.com/Artists/Arduino/KattivaGallows.asp
I am still trying to figure out were to put the wood at to cut it with the saw blade. J/K ohh the perrils of Pauline and all that stuff. Looks good Kagato98 . You might want to pop over to the url above and see how Arduino's did it with his Gallows figure. I kind of liked the way it starts up then swivils down .
kawecki ( ) posted Sat, 04 January 2003 at 10:21 PM
Poor Judy, what she did to you????
Stupidity also evolves!
Kagato98 ( ) posted Sun, 05 January 2003 at 11:10 AM
Muhahahaha :D !
