Make sure that you don't already have the items. You can only buy a PC item once. If you try and buy it again then two things happen. 1. If the item is a PC item only you will get a warning that you can only pruchase the item once. 2. If the item is also available as a regular item then the cart charges you the regular price (minus discount). I almost found this out the hard way but fortunetly noticed that the prices weren't what I expected. It turned out I already had the PC item but I had forgotten about it. Eric J
oh didnt know they tracked me.... and I've been spending hours loading all my purchases into a database! ah well, keep the fingers limber! I have been getting the $1.99 on all other items in my cart and have not left the Platinum area (that is how I messed up last time) yet the items toonkitty and mike face morphs which i put in basket from platinum - are showing wrong prices. I have selected items after the 2 above items to buy and they are $1.99 so believe I am still logged on... Ah, well, will just buy and let them figure out what is wrong or correct me like they did last time as I do want kitty to go with puppy! Thanks y'all
I kept having that problem when trying to get the Charger Tack through Platinum. I even e-mailed DAZ about it, and they said if I already had the item, it would do that. Well, when I went to check my archived items on the many CD's I've made, sure enough I had already bought the item. You can only buy each item once through Platinum club. Melanie
Does the puppy come with a collar and sweater, like the kitty? The items aren't listed in Features, although one of the pop-ups shows the little fellow wearing them. The page says "Compatible with Toonimal Kitty Accessories", so is he simply wearing them for illustrative purposes?
My credit card is still warm from earlier this week. DAZ is starting to feel like EverQuest; you think you're done, and then they suck you back in with another expansion pack.
"Tag, you're it."
Yes, I see now that he does come with a collar.
I was initially concerned that something was wrong with my download; how can the UV template be larger than the product itself? It installed successfully and loads fine, though, so I suppose it's all right.
The readme mentions MAT files, but I don't see any. Admittedly, it only has the one texture, so it doesn't really need them.
I like him. He animates well. Just what we need to continue aggravating those cuteness-intolerant forumites.
Video clip (MPEG format, 373KB)
I really need to start using a different test file.
If you get someting really wierd like that send an email to: Reachel White reachel@daz3d.com but only for webSTORE related things.
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
The puupy and kitten have a similar origin so stuff often will mix-n-match between them.
-Anton, creator of
since 3-13-07
Hello, It comes with a collar that has a heart shaped tag, that both can wear. Puppy can also wear the Kitty sweater and bell collar, but does not come with them. I tried to keep them mostly compatible in the body so people could swap accessories to both. No MAT files, since it only has the one texture, which loads applied. ML
MallenLane, you do good work. I'll be installing my copy of the kitty soon to keep this little scamp company.
I've noticed that he has a tendency to go a bit wall-eyed when the Eyes Up-Down dial is used. You might want to check the deltaAddDelta values in your ERC code to make sure they match for both eyes. I've already fixed mine.
Well, dont know if anyone else has had this problem but went to buy the "kitty" while signed into the Platinum site and it charged me $14.95 with 30% discount even though the page to buy it states platinum price for toonkitty is $1.99...... same with Michael's Face Morphs & Textures and that charge is $24.95 originalin card than 30% discount. Am I missing something or doing something wrong? If you know what I am doing wrong please let me know as I have ended up paying 2 much more than once! as I was not logged onto the Platinum site (but this time i am). Also, for you V3 folks - they put up the Second Skin Hosiery and the Second Skin Jeans & Tops Textures and it does come out at $1.99 each.
