Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 2:03 pm)
heyas; a lot of kozaburo's hair uses double-sided polygons. you MUST get rid of those to render them in p5. if anybody else has come up with another solution, i haven't heard it. :/ if it's not double sided, make sure you have backface culling turned OFF when you render. very thin items sometimes come out patchy with backface culling on.
Yes, as far as I can tell, it has something to do with the double-sided polygons. Poser 4 is less sensitive to such things, but Poser 5 doesn't seem to like them, even with the old P4 renderer. No official fix as yet, although there is a simple workaround.
Plug your texture map into the Displacement channel and set it to a very small value (0.01). I'm not sure why this works. My theory is that the displacement manages to separate both sides of the polys just enough to avoid the effect.
Further reading:
http://www.renderosity.com/messages.ez?Form.ShowMessage=917912
http://www.renderosity.com/messages.ez?Form.ShowMessage=905904
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=306070&Start=1&Artist=Firebirdz&ByArtist=Yes
I got that problem too in Poser 5 and it was even more patchier. However, I realised that all the short hair textures were in the same texture folder. I took them all out and hid them save the texture colour I wanted which I renamed to the orginal name. It worked great after that. Not sure if that works for you but it did for me. The attached link is an image I did after I did the changes. Not sure if I am doing this the unconventional way. LOL.Attached Link: http://www.renderosity.com/viewed.ez?galleryid=308702
OK - so the picture is finished - Thank all of you again.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
When I apply Kozaburos short hair to Vicky 3, It comes out with black patches, as you can see over the ear in the picture.
I have tried to tweak the material room as far as colours go - but to no avail.
Does anybody have a good explanation??
