Fri, Nov 22, 5:02 PM CST
Subject: need help with ISOP's MLDress
curtskinn ( ) posted Sun, 05 January 2003 at 10:15 AM ยท edited Fri, 22 November 2024 at 12:22 PM
I downloaded ISOP's MLDress and unzipped it like I was supposed to do but when I go and try opening the dress it says it won't open. I have Poser 4.03 if that will help in giving information for the dress. Any idea what I am doing wrong and how I can correct the problem
lululee ( ) posted Sun, 05 January 2003 at 11:18 AM
You might try unzipping everything into it's own file folder(not in your runtime folder). Look at the readme and see EXACTLY where he says to put the files, particularly the .obj files. Sometimes files don't unzip properly. i unzip everything to a dummy folder because of that. Make sure the .obj file is in a folder with the EXACT spelling that he has told it to go. I hope this makes sense.
pendarian ( ) posted Sun, 05 January 2003 at 11:18 AM
Curt, I think I remember when I installed that dress, the obj doesn't go in the right place and I had to manually install it. Open the cr2 in a text editor and look to see where it says the obj for the dress should be. Move the obj to the correct geometries file then it should work fine. Pendy
Lovely Lady ( ) posted Tue, 07 January 2003 at 12:32 PM
Iso does not package his zip files to automatically install. You must look at the path in Winzip to get the idea where they should go and create your own folders. e.g. "MLDress/runtime/geometries/ISOP/MLDress/" as the path in Winzip. Ignoring the first part of the path you would see where to put the object files. i.e. runtime/geometries/ISOP/MLDress/ cr2 files can go into any folder. I hope this helps.
