Fri, Jan 10, 12:52 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 9:07 am)
Subject: Nipples and texture maps
Lothaekor ( ) posted Wed, 26 April 2000 at 9:51 PM ยท edited Fri, 10 January 2025 at 12:26 PM
I'm trying to create a character using the P4 Nude female, but I'm doing all the clothing as a texture and a bump map. Only problem is that when I render, I keep getting the nipples the original color, when they shouldn't be there at all. I've used Krel's No nipples morph... Is there any way to get rid of them? Lothaekor
kristyn ( ) posted Wed, 26 April 2000 at 9:55 PM
I know this might be a dumb question... but did you make sure you turned the color of the nipples to white? Also, I've found that if the texture doesn't line up exactly you get some weird things happening...
Krel ( ) posted Thu, 27 April 2000 at 5:46 AM
Another thing is you must select "apply texture to entire figure" for the texture to be applied to the nipple area.....even then it is hard to completely hide them with a texture unless that area is a dark color...... Krel
black-canary ( ) posted Thu, 27 April 2000 at 11:16 AM
I had this problem constantly, and it was a combination of both of the above factors. So go to the render/materials window and be sure you either "apply to entire figure" (a bad idea with vicky, because she uses 2 textures!) or select "nipples" from the list of materials and set the texture on the nipples, AND make sure they're the same color as the body skin (white is the best, but if you're looking to darken down a texture without redoing it you can use a light color in the flesh ranges under it-just be sure to match it exactly to the other body parts). This problem will also crop up with the eyebrows & lips and so on when you're using a face texture. And the toenails and fingernails. But none of these are obvious in quite that same special way...my first set of poser renders were quite hilarious due to this problem, since I tend to "dress" posette in textures instead of prop clothes! Mary
