Sat, Jan 11, 1:34 PM CST
Subject: P5 Changing a texture after a certain frame ?
ablc ( ) posted Wed, 08 January 2003 at 1:37 PM ยท edited Sat, 11 January 2025 at 12:36 PM
Is there a way to change a texture after a certain frame ? I want to change the texture of one person after the frame 10. I've found the "frame" node but i dunno how to use it. Thanks Laurent
DocMatter ( ) posted Wed, 08 January 2003 at 2:49 PM
I use the blend function to change textures on objects. 1) Connect the blender function to the top and third nodes; 2) Connect the 2 textures you want to the 2 inputs on the blender node; 3) I can't remember exactly, but varying the value from 0 to 1 will change from one texture to the next. Play around with it to be sure. Hope this helps.
Little_Dragon ( ) posted Wed, 08 January 2003 at 6:07 PM
The frame node only outputs the current frame number. It's a variable.
I posted some examples of animated materials (with illustrations) in an earlier thread:
http://www.renderosity.com/messages.ez?Form.ShowMessage=994366#7
As an experiment, variable nodes were used to determine the rate at which the Blending value changes, but it's usually easier to click the little key-symbol next to the number and manually keyframe the changes.
