Fri, Nov 29, 6:43 PM CST
Photoshop F.A.Q (Last Updated: 2024 Nov 26 6:58 am)
Are you up to the challenge??
Subject: The magic wand?
archlite ( ) posted Thu, 27 April 2000 at 6:27 PM · edited Fri, 29 November 2024 at 4:24 PM
Hi, A quick question. When I render something in Bryce say a jet with a light blue or green background I save it in PSD format and then I open the image in Photoshop. I use the magic wand to try and select just the image of the jet and move the image of the jet into another image say a Jpeg. Is there a tutorial or does anyone have the step by step process of this because I am fumbling around with it but the entire jet image will not paste over and I am having some trouble trying to select the whole thing. Help please. Thank You
"But I being poor, have only my dreams. I place my dreams at your feet. Tread softly, because you tread on my dreams." --William Yeats
dlm ( ) posted Thu, 27 April 2000 at 6:58 PM
If you have saved the image ie the jet against a solid coloured background then just use the wand to select the background then go to the selection menu & select "inverse".You should then be able to copy the jet & paste it onto a new clear layer.Load your Jpeg or whatever & copy & paste it over your background. A little tip before pasting the Layers together make sure the jet image layer is selected go to the layers menu -matting-defringe.This helps blend the top image with the background.
bonestructure ( ) posted Thu, 27 April 2000 at 6:59 PM
The magic wand is the wrong tool for this. You need to use the lasso tool or the pen/paths tool. Personally, what I do, and I do a LOT of compositing, make a duplicate layer, make the layer on the bottom invisible, then use the freeform lassoo tool to cut away everything in the picture except the jet. Then select all/edit/copy/paste into your new picture and your composit is ready for transforms, on it's own layer, and your original source picture is untouched
Talent is God's gift to you. Using it is your gift to God.
Traveler ( ) posted Thu, 27 April 2000 at 7:28 PM
In Bryce: -Render the jet as normal. Dosen't matter on what sort of background. Save this pict. -Switch the render mode to Mask -Select the Jet -Render again (This will be a black and white outline) -Save this as a second pict. In Photoshop: -Open the render -Open the mask render. -Select all of the mask render. -Copy -Paste this into the standard render document. -Select color range, select the black part of the mask render. -Switch to the background layer. -Hide the Mask render layer. -Copy You now have a clean copy of the jet on the clipboard, paste this into your .jpg image. -Trav
archlite ( ) posted Thu, 27 April 2000 at 9:57 PM
Thanks a lot I'll try all of those in the morning thanks again.
