Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Injecting is really easy inside the 'Poses' library you'll see a load of files called !V3__________ these are the injections you can chose to add what morphs you want or add them in clusters of all at once which takes forvever... YOU MUST NOT RENAME THOSE FOLDERS, otherwise they will not work! ;) Have Fun -=SimderZ=-
I got the V3 upgrade from V2 and then got her morphng pak too and when i go to try some of the poses or morphing pak stuff they dont take effect like nothing even happened. Just about anything i do with V3 wont take effect. Im using 4.03. Could i be doing something wrong?
