Wed, Feb 12, 1:21 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: markdc/render-separate
EvoShandor ( ) posted Wed, 08 January 2003 at 11:04 PM · edited Sun, 04 August 2024 at 6:48 PM
mark, I'm getting this error when I attempt to run your "render-separate" script. You know what this means? evo
markdc ( ) posted Thu, 09 January 2003 at 12:49 PM
What sr of pro-pack are you using? This script needs sr3 (v4.2.1.179) -Mark
EvoShandor ( ) posted Thu, 09 January 2003 at 1:07 PM
oh, ok, I am at work right now, I'll check it when I get home, thanks...I thought it might've been a problem with V3 or something.
