Sat, Jan 18, 4:02 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 2:02 am)
Subject: Problem with Daz3d V3 Bikini
Norpan777 ( ) posted Thu, 09 January 2003 at 7:18 AM · edited Tue, 14 January 2025 at 8:37 PM
I am very new into this stuff but like it a lot. However when I try to use V3 Bikini I get some kind of error. It try to locate some file ???.bum But I can't find it. I think the file is JPG..? This also happens with some other textures. I use Poser 4.0.3 Anyone know how to fix this problem?
canary3d ( ) posted Thu, 09 January 2003 at 7:22 AM
it's trying to find the bump map. But it has to create the bump map the first time you load the file, so you get an error. Do this: 1. tell it "no" to continue looking for files 2. find and load the ????bum.jpg file from wherever it's loading the regular texture--load it as a bump map on any old part 3. when it says it's going to create the .bum file say ok 4. remove the bikini from the scene and reload it. All the textures should come in properly this time. bit of a pain, innit!
Norpan777 ( ) posted Thu, 09 January 2003 at 10:02 AM
I did this and created the bump map (BikiniB.bum). Then when I click on the bikini nothing happens, no error message, no bikini. What am I doing wrong?
canary3d ( ) posted Thu, 09 January 2003 at 3:03 PM
you mean when you go to load it into the scene? you have to select it in the library and click the double-check icon at the bottom to load it into the scene. Then you can conform it.
Norpan777 ( ) posted Thu, 09 January 2003 at 3:44 PM
That's the problem, I don't have the double-check icon, only the single-check icon... I have the double-check icon on other clothes though. Any ideas?
