Wed, Jan 22, 8:38 AM CST
Renderosity Forums / MarketPlace Showcase
Welcome to the MarketPlace Showcase Forum
Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Jan 22 7:06 am)
Welcome to the MarketPlace Showcase Forum. The Showcase Forum and Gallery are intended for all commercial related postings by active Renderosity MarketPlace Vendors only. This is a highlight area where our membership is invited to review in greater detail the various art products, software and resource site subscriptions available for purchase in the Renderosity MarketPlace.
Subject: GaryT's Fantasy Archers !!
GaryT ( ) posted Fri, 10 January 2003 at 10:15 AM · edited Tue, 07 January 2025 at 12:59 PM
Attached Link: GaryT's Fantasty Archers
Here is my New and Improved Fantasy Archers Set !! Available now here in the Market Place and at Hometown3d.com
Many new improvements have been made to this set to make it more versatile including morphs and a complete rework of each outfit...
LadyJaiven ( ) posted Fri, 10 January 2003 at 10:18 AM
Awesome work, mister ;)
aleks ( ) posted Fri, 10 January 2003 at 11:29 AM
i was intrigued also, but i must say that the promos are way to small. they reveal almost nothing about the model except the general form which could be with a very low polygon count. i'm interested in how models bent, how they follow the form, folds, wrinkles, edgeness in curves and so on. you mentioned some morphs for the hips part. is it all? are there some general body morphs to follow vicky's morphs? this i don't understand: "...you need to go to object/properties and click next to the word bend."
GaryT ( ) posted Fri, 10 January 2003 at 12:30 PM
Aleks, If you od a search in the Poser Gallery for GaryT you will see more Images using these outfits, hopefully they will help you with the bending and everything... Now as far as the morphs, no there are no mrphs for different body type on these, just for the hip peices, they hang down and use morphs to allow you to move the body around with out them going all over the place.... now as far as the object/properties/bend... the shoulder pieces are setup with the bend option off to allow for them to stick straight out when vicki is standing straight but if you raise her arm and the bend option is off then the arm will go through the shoulder peiece, but if you turn bend back on then it will move with the arm in the up position.. I hope this helps you... GaryT
aleks ( ) posted Fri, 10 January 2003 at 1:23 PM
doh, forgot about the gallery :) yes, thanks.
