Sat, Feb 8, 11:57 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Creating Geometric Shapes in Carrara
pc_artist ( ) posted Sun, 12 January 2003 at 6:29 PM · edited Sat, 08 February 2025 at 12:32 AM
I know 1 can do a Cube and Isohederon ( whatever the name is ) An Basic Prism shape is easy But how would one do shapes for example like a Pentagon based object with 5 faces and 5 sides in Carrara 2?
" The Only Limit is your imagination "
twillis ( ) posted Sun, 12 January 2003 at 6:45 PM
Attached Link: http://www.uwrf.edu/~ll63/M247/geom/duals.htm
Well, I'd use the vertex modeller. You can make a pentagon by creating a oval with 5 sides. A Pentagon shaped prism would be just a matter of extruding the 5-side oval. Or, you could use 20 pentagons to make a regular solid. I've included a link that shows the 5 regular solids.
pc_artist ( ) posted Sun, 12 January 2003 at 6:50 PM
well 1 simple Extruding is 1 thing.. a complex way is another..
hartcons ( ) posted Sun, 12 January 2003 at 8:59 PM
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=5891
might find something helpful in this collection
pc_artist ( ) posted Sun, 12 January 2003 at 9:15 PM
thanks Hart my aim was to try and make stuff like this myself, though.
Nicholas86 ( ) posted Sun, 12 January 2003 at 11:54 PM
Not sure what your difficulty is, twillis explained exactly what to do...have you solved your problem yet, I know you are looking for platonic solids, which are relatively simple to create...at least I think you are? Perhaps if you explained your dilemma more? Brian
pc_artist ( ) posted Mon, 13 January 2003 at 12:05 AM
Yes.. am wanting to create Plantonic Solids and simular suject.
twillis ( ) posted Mon, 13 January 2003 at 7:58 AM
I think making something like a dodecahedron will take some math figuring. Creating 20 pentagons is easy, but figuring out where they go is a bit more difficult, eh? Let me chew on it a bit... I have an idea for an approach that might work, but haven't had a chance to figure out the details and test it.
pc_artist ( ) posted Mon, 13 January 2003 at 9:10 AM
ok - Twillis
twillis ( ) posted Mon, 13 January 2003 at 9:38 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=662183
Meanwhile, you might check the above link for a discussion we had about making shapes using formulas.
pc_artist ( ) posted Mon, 13 January 2003 at 9:54 AM
just saw that but I am not good a formulaes and complex mathamatic... Looks like this idea of mine to make geometric shapes is going to be more involved that I hoped for.
twillis ( ) posted Mon, 13 January 2003 at 10:08 AM
No! Prithee, don't be faint of heart! We will NOT be defeated. We WILL tame this BEAST. I do so vow, upon my honor and upon the Divine Cheddar which dost sustain me. We shall PREVAIL, and thus join the Sacred Order of the Dodecahedron. The glory will be OURS. No, really, I'm working on it. It's gonna be doable, I promise.
keithw ( ) posted Mon, 13 January 2003 at 10:36 AM
Have you tried using the vertex modeler? Use "insert sphere" under the "Insert" menu. Changing the number of polygons to 10, 12, etc. and see what shapes it creates. I think 12 will give you an object of 12 pentagons Keith
Pefo ( ) posted Mon, 13 January 2003 at 12:52 PM
Attached Link: Polyhedrons
See : http://gianf.free.fr/polyhedrons.zip (polyhedrons format .dxf) Jean P.
twillis ( ) posted Mon, 13 January 2003 at 1:36 PM
Attached Link: http://www.toshen.com/shoji-lamps.asp
Here's another link that may seem a bit off-topic (it's about lamps), but click on "Side topics" and then "dodecahedron". Actually, all of the discussion of this guy's construction approach looks like it could be adapted for "virtual" construction.
Pefo ( ) posted Mon, 13 January 2003 at 2:03 PM
Attached Link: http://gianpf.free.fr
For creating geometric shapes , you can : 1 - Create the geometric shape with a soft like Mathematica or maple 2 - Export in DXF format 3 - Texture with Carrara Studio Jean P.
twillis ( ) posted Mon, 13 January 2003 at 9:16 PM
OK. Well, here's a recipe for a dodecahedron. I'll post a quick step-by-step for now, later I can go into more of the why-for if anyone is interested. 1. In the vertex modeller, insert an oval U size 2, V size 2, 5 sides, perpendicular to the Z axis. This will create a pentagon. 2. Select the pentagon. Copy it, paste. Then, Select--> Move, and move it in the X direction 0.81. This will align one side of the pentagon with the Y-axis. 3. Rotate the selection -116.56 on the Y axis, then move it back in the X direction -0.81. Copy. 4. Paste. Rotate 72 degrees on the Z axis. 5. Paste. Rotate 144 degrees on the Z axis. 6. Paste. Rotate -72 degrees on the Z axis. 7. Paste. Rotate -144 degrees on the Z axis. 8. Select all. Then Selection --> Weld, using a custom tolerance of 0.01. This will reduce the vertices to 15, and complete the bottom half of the shape. 9. Copy, then rotate on the X axis 180 degrees. 10. Then rotate on the Z axis 36 degrees. 11. Then move in the Z direction 2.62 inches. 12. Select all, the Weld, using a custom tolerance of 0.01. 13. Then Selection --> Crease edges --> All 14. Amazing your friends and families with your mighty dodeaohedron modelling powers. 9.
pc_artist ( ) posted Mon, 13 January 2003 at 9:27 PM
AWW twill.. you didn't have to go to all that effort.. tHank you anyway
twillis ( ) posted Mon, 13 January 2003 at 9:41 PM
It was a matter of HONOR, man! Not only did I owe it to the Sacred Cheddar, but I had to defend my position of Baroness of the Vertices. Actually, it's occured to me that each half could make an intresting hand for a robot, so then of course I had to try and make one.
twillis ( ) posted Mon, 13 January 2003 at 9:42 PM
OK, I admit, no one really calls me Baroness of the Vertices. Except my boyfriend, and that's only when we $%##)(NO CARRIER
pc_artist ( ) posted Mon, 13 January 2003 at 9:48 PM
To Twill : You are very kind to help.. thnak you..
Nicholas86 ( ) posted Tue, 14 January 2003 at 7:40 AM
I think he/she thinks you are odd twillis;)
twillis ( ) posted Tue, 14 January 2003 at 8:30 AM
Who, me?
pc_artist ( ) posted Tue, 14 January 2003 at 9:55 AM
I do not think Twillis is odd.. Just nice...
bluetone ( ) posted Tue, 14 January 2003 at 9:26 PM
Well, the rest of us think she's odd... but our kind of odd ;> And nice! AND, the Baroness of the Vertices. (But don't tell her boyfriend!)
pc_artist ( ) posted Tue, 14 January 2003 at 11:10 PM
Ok - lol
