Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Some additional things. First: Mac version. Second. It has to do with bump maps (.bum) from Poser. After importing into a "fresh" Vue file, i can click the error message away, but then Vue crashes. Somewhere deep in the back of my brain something says, that i have read about a problem with Vue Poser BUM files on a Mac. But i can't remember. Maybe someone else does remember.
merci bien Guitta. The first part worked. I think in Poser i forgot to click onto "apply texture to entire figure", so the bum (bum bum you're dead!) was still somewhere applied. The scond part didn't work. I renamed the (copy of the) bum file to jpg and tried to apply that manually. Same error messages and crash. Unpleasant but that's how life is - sometimes. Walther
i want it to work too :-)) I tried that already - to load the bum file into Photoshop. No way! I tried now as well to import the pz3 file on the windows machine and to save the file there as a vob. Loading this file on my Mac, obviously Vue asks for the tif and bum file. When i guide Vue to these files and "point" to the bum file Vue crashes as well. bad luck and trouble! Walther
Walther, what I don't understand is, how Vue can ask for a bum file, if there was no bum file when you saved your pz3??? Maybe there is another bum for something else in your Poser scene that you forgot to "unable"? I remember when this (Vue could nort read bums on PC)problem existed in Vue 4.5 (?), I always disabled all the bum files and applied them manually in Vue (opened bumps tab-->edit function-->loaded the jpg).
Sorry - missunderstanding. In this case i tried to load (and save it as a vob object) the file on the PC with the bum file embedded. The second problem is, that i am unable (blame me probably) to save the Poser file without bump (i checked all (2) elements for bumps, disabled them., and when i recheck the elements the bumps are "happily" back again). To get rid of the bumps work in all other cases but not with this specific figure. I have to do the Poser file again "from scratch". I am testing another possibility as well and will let you know.
Well, finally found a workaround. Use Lemke's GraficConverter and convert the BUM files to jpgs. Then apply those in Poser to the figure. If you do this in Vue, you do have to go through a lot of individual elements which form a figure - that's a little boring. The import in Vue with these files is possible. The only question is, wether the conversion or the use of jpg bump maps does make a difference compared to the original bum files? Walther
