Can you try and narrow down the problem? I'd try turning off the Firefly options, maybe polygon smoothing could be it. Then, if that doesn't work, try removing the figures/props in your scene one by one until it works. Do other scenes work with your current render settings? Do you have the latest service release installed? Can you watch memory usage while rendering?
I think you are right about the lights. I took "stewers" suggestion and started eliminating some of the actors from my scene and Fire Fly moved beyond the point where it was hanging up: which was the "render shadow map>adding objects" for the first light in my scene. I think by simplifying the scene, therefore the shadows, for light 1 that allowed it to move forward. I'm going to explore this a little further and see if I can narrow it down more. I'm also going to upgrade my video card now that faster ones are available.
You can reduce the shadows-- that's what I do, cut the shadows off of half the lights. You might try removing "remove back facing polys, I never use it. Is raytracing on? And. . . that's a lot of figures, maybe twice as many as Firefly can take. Is it possible to use low res versions of some of them? Emily
Thanks Emily: yes I had "remove back facing polys" checked & I unchecked raytracing. All though I haven't gone further in my experimentation; I do think it is the lights more than the figures. Unfortuneatly, shadows in this scene are important to me, I am trying to simualte what a stage setting would look like. I'll keep on plugging away when I get a little more time. Thanks again.
