Community Center F.A.Q (Last Updated: 2025 Feb 04 12:04 pm)
Easy enough to find the worst offenders -- list Free Stuff by most downloaded. I get the impression that people keep checking back on things that have been dead since 2000 trying to download them. I was going to download all the RFS pages and run them through a script to send a status request (no actual bandwidth slurping, just a check for 200-OK or not) for all of them, then spit that out into a list.
It's hard to know if the items are just off line for a few days or forever...
You can't call it work if you love
it... Zen
Tambour
An idea then: add a column to the FreeStuff database called active
char(0). Run a script to check the statuses of every one nightly and if it doesn't return 200-OK, mark it NULL, and if it is okay leave it ''. (In MySQL there is no Boolean datatype, but a char(0) works just as well. The value is either NULL or '' (nothing but defined as nothing). This works as a boolean. Modify the output to only list ones WHERE active IS NOT NULL
If I compile a list of the broken free stuff links, can something be done about it?
