Thu, Feb 20, 2:40 PM CST
Forum Moderators: RedPhantom
Subject: Importing .Obj file into P5... can it be done?
MacXimus ( ) posted Sun, 19 January 2003 at 10:38 PM ยท edited Wed, 19 February 2025 at 9:58 PM
Hi y'all, I've recently been fiddling around with making my own props but I've run into a strange dilemma. I can't figure out how to import the .obj into P5. T'was easy in P4, but P5... The "Import" function doesn't give that as an option. I've looked under other headers but to no avail. Any tips?
pdxjims ( ) posted Sun, 19 January 2003 at 10:59 PM
  1. Go to the file menu 2) Select Import 3) Select the type of object (3DS, Wavefront Object, etc) 4) Select the object you want to import 5) You're done. You can then save the object into the prop library.
MacXimus ( ) posted Mon, 20 January 2003 at 7:16 AM
Well, that's just the problem, P5 isn't giving me any options such as 3DS, OBJ, etc. The only options are shown here in the attatched image. Very frustrating. I've tried each one of those options but none of them have .obj as an acceptable file format.
pdxjims ( ) posted Mon, 20 January 2003 at 8:16 AM
That is definitly a problem. Contact CL on this one. My copy of P5 has the complete list.
tasquah ( ) posted Mon, 20 January 2003 at 9:11 AM
Or if you still have P4 installed on your computer just use it to import your OBJ files .
_dodger ( ) posted Mon, 20 January 2003 at 10:58 AM
or copy over a ppp2 with an external OBJ reference and point it at the new OBJ
