Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 1:20 pm)
Using your Poser 4 library in Poser 5 is simple... literally as easy as adding an item to an existing library in Poser 4... Actually, it's almost the same process, you just have to be at the top level of the libraries and it asks you to find the runtime folder you want to add instead of naming anything...
Im not at my home computer so don't have P5 in front of me but I think I can walk you through it. In your P5 library at the top of every page is an up folder. click on that till you get to the one that shows both the p5 and the download library at the bottom of that page is an add button, click on that and navigate to your P4 runtime select that hit OK and your p4 library has been added. that simple.
You just keep clicking up in the libraries column until you reach a folder with an arrow on it-- double click and wait a bit if it's the first time-- poser is looking for the others. It will show you Poser 5, downloads, and Poser 4-- maybe more if you have more on other disks, both of mine are on C. You click on Poser 4 and you have option to everything there. You need something in Poser 5 again?? do the same thing only this time click on Poser 5. It's very easy. Emily
hy again i m planning to buy poser 5.0 and i want to know if i can share my libraries between my existing installation of poser 4.0 pro pack(that i want to keep)and an install of poser 5.0 so i can save space on my hard drive thanxxx
