Mon, Jan 20, 2:54 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Scaling point confusion
fls13 ( ) posted Wed, 22 January 2003 at 4:53 PM ยท edited Mon, 20 January 2025 at 11:25 AM
Poser's preloaded props and figures have a scaling point that's even with the floor, or 0 on the Y axis. When I import objects I've modeled, they scale from the median point of the object, which means dropping it to the floor every time I scale it. I've also noticed that when I export primitive props that originally scale from 0.00 Y, when I reimport them they also scale from the median point. What am I missing here?
geep ( ) posted Wed, 22 January 2003 at 9:27 PM
Attached Link: http://www.renderosity.com/messages.ez?&Form.ShowMessage=1030260
You might find some helpfull info in one of my tuts. (see attached link for one of them)
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
_dodger ( ) posted Wed, 22 January 2003 at 9:44 PM
Open the joint editor and move the centre to the bottom.
fls13 ( ) posted Wed, 22 January 2003 at 10:18 PM
No joints on the prop. But Dr. Geep's postings solved my problem. Go to show origin in objects properties and then zero out the translation dials. Thanks Doc :O)
_dodger ( ) posted Wed, 22 January 2003 at 11:02 PM
Doesn't matter if there are joints. There's still a centre. WhatI said would have solved it right away.
fls13 ( ) posted Wed, 22 January 2003 at 11:22 PM
Both solutions work beautifully. Like they say, there's more than one way to skin a cat. I knew the fix had to be simple, but this one was TWO simple! :O) Thanks again.
_dodger ( ) posted Thu, 23 January 2003 at 2:24 AM
nods Another thing that JP adjusting on non-jointed props does wonderfully -- many props, on import, start out gimbal locked. Opening up the joint editor and clicking 'align' will fix this up nicely.
