Mon, Nov 25, 5:09 AM CST
Subject: Import size?
DCLXVI ( ) posted Thu, 23 January 2003 at 1:13 PM · edited Fri, 01 November 2024 at 12:50 AM
How big of a file can be imported to Bryce? And what's the best format for import? Thanks.
Stephen Ray ( ) posted Thu, 23 January 2003 at 4:46 PM
This will greatly depend on the amount of ram on your computer. OBJ is the smoothes mesh... 3DS is usually a smaller file size but will probably require smoothing.
Stephen Ray
Doublecrash ( ) posted Thu, 23 January 2003 at 8:52 PM
I think it depends on your tastes. I prefer OBJ because the models are almost perfect when imported, but DXF works well after a smoothing pass.
Tankgirl ( ) posted Fri, 24 January 2003 at 12:25 AM
I've good luck with .3ds and .lwo for models, so far size has not been a problem, my Bryce hates .dxf, just refuses to import 'em, oh yes and poser files are ok too...
Quest ( ) posted Fri, 24 January 2003 at 5:39 AM
Of the most familier formats, Bryce imports ".obj" together with their texture maps. For 3ds files you need to convert them from xyz to uvw map format to get the textures right and you will still need to work on the bump maps.
