Thu, Feb 20, 2:25 PM CST
Forum Moderators: RedPhantom
Subject: Toothbrush?
armitron ( ) posted Wed, 22 January 2003 at 9:30 PM ยท edited Thu, 20 February 2025 at 2:03 PM
I need help finding a good toothpaste and toothbrush for poser. Thank you in advance for you help
Little_Dragon ( ) posted Wed, 22 January 2003 at 11:48 PM
None of these are in Poser's native file formats, so use the import feature ....
Toothbrushes:
PlanIT 3D : electric toothbrush (.3ds); look under Meshes --> Household.
The 3D Studio : two regular toothbrushes (.3ds)
lynnart (.lwo)
Toothpaste tube:
Fantasy 3D (.3ds)
lynnart (.3ds, .obj, .lwo)
_dodger ( ) posted Thu, 23 January 2003 at 6:40 AM
Justa note on importing things in 3Ds format and many others: You will nto be able to set up the centre and endpoint to make any sense on most imports, as most of them are scaled way too big for Poser, so on import they will be scaled down and will act weird when you open the joint editor to set the centre and endpoint. Here's a way to get around that: Import the object to Poser. Export the object to a Wavefront OBJect. Import it again. Also, as a recommendation, when you import you will generally want to say 'No' to the 'Weld identical vertices' question. Don't tick anything when you export the prop unless it's supposed to be posable. -- Dodger
armitron ( ) posted Fri, 24 January 2003 at 10:47 PM
Thank you for your help.
