actually, the joints in some places, are cut differently for v3 than in v2. (collar and knee region.) perhaps, it would help if you cut them up to match the new cuts in v3 using uvmapper.) this is all confusing to me. in one thread, though, steveshanks says all you need to do is use pwizard...but, after you have cut the mesh to coincide with the new v3 cuttings.)
Okay, I'm trying to use Uzilite's Blouse to fit Vicki 3. I used P-Wizard to change the joint parameters, then tried using Morph Manager to put all the morphs from the original blouse into the new CR2 blouse. The morphs copied okay, but when I go to adjust them in Poser, they do not work. Any ideas or suggestions much appreciated!
