Wed, Dec 18, 7:48 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 17 1:08 pm)
Subject: Poser 4 ground and shadows
Virum ( ) posted Sun, 26 January 2003 at 7:23 PM · edited Wed, 20 November 2024 at 3:25 AM
Hi. I am having troubles modifing the ground prop. I can't seem to get it to show. And how do I change its color? How do I fix this? Also, shadows on the ground aren't rendering either, although shadows on the figure do. Thanks. :)
Virum ( ) posted Sun, 26 January 2003 at 7:25 PM
Also, is there a way to make parts of props and clothing (mainly clothing) transparent?
tasquah ( ) posted Sun, 26 January 2003 at 7:45 PM
Dont know about the first one I never use the ground plane only other props or add it in in post work. 2nd question , you could use either double click the part of the prop you dont want to see and clik invis or you can make a transparentcy map for it.
TrekkieGrrrl ( ) posted Mon, 27 January 2003 at 2:53 AM
Ctrl - G makes the Ground show up :o)
vilters ( ) posted Mon, 27 January 2003 at 2:09 PM
Ctrl G makes the ground show. Then in the P5 material room you can put a texture on it. In P4, you can also put the texture on the ground in material setup. And a bump map and or a displacement map in P5. And when you adjust the lights to put a shadow on the ground, it will render. Here a little tryout : just added a picture to the ground map, and only one light at 45 up. Hope this helps, Tony
Virum ( ) posted Mon, 27 January 2003 at 9:34 PM
Thanks. :)
