Sun, Feb 2, 9:17 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
Subject: DAZ Aquatica Reef and V3 Mertail ReadMe's
orn4rk ( ) posted Mon, 27 January 2003 at 4:39 PM · edited Sun, 02 February 2025 at 9:09 AM
The above products install ReadMe files titled "ReadMe" only. Consequently, the later installation will overwrite the former ReadMe if you do not change the name of the first file. - Bjorn
PheonixRising ( ) posted Mon, 27 January 2003 at 5:41 PM
ack. Look for an readme added. Calling them now. This is the Aqautica Reef one. it is fairly simple: Reef and AtmoSphere is in "enviornments" folder in figure libarary. Using the AtmoSphere: -The sphere is like a bowl;round on one end and flat on the other. -Always have the flat side of the AtmoSphere facing the camera. -Keep objects inside the first bowl of the sphere and not piercing the "face" of the bowl. To get more depth of field scale the sphere smaller so the objects in your scene are swallowed by more of the layers of the AtmoSphere. Rendering with or without shadows will yield different results. ------------------------------------------------------------ The mermaid is really straightforward. There is a motph on the hip and thing for bending. it is on by default but will reset when conformed. Reset the dials manually. Only to of them. This info is on the product page. :)
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
Marque ( ) posted Mon, 27 January 2003 at 8:15 PM
I got the reef one but it did copy over the mermaid one so it helps to get a copy from Daz. I had a problem with the thigh popping out of the suit so I will go check that out. Thanks! Marque
PheonixRising ( ) posted Mon, 27 January 2003 at 8:31 PM
A few morphs didn't work on the mesh so they weren't added. Check the list of morphs on the product page.
KateTheShrew ( ) posted Tue, 28 January 2003 at 2:01 AM
You can always do what I do - install to a temp directory, then go in and rename the "readme" file (I usually just stick the name of the product on it so I know what it goes to) and THEN install the second item. Voila! No overwrite. Kate (who sticks all the readmes in a folder named "documents" so she can just get rid of them all with one click snicker)
