Photography F.A.Q (Last Updated: 2025 Jan 22 8:17 pm)
word of advice: The Cloning Brush is your best friend here. Use a hard clone brush, and swivel back and forth between the two. Also, make sure to clone from many different areas of the image, cuz even if you do use the clone tool, if you only use it near the seam itself, it'll still be really visible that the images were "glued" together if you don't. also... the three sheds... two of them are a lot "bluer" then the other (the ones on the right). Might wanna tweak them colours a little more...
but how should i go about "tweaking the colors"? that seems to be the problem not sure which color elements to adjust- one either comes out too blue or yellow, then the snow & sky are off, see the snow & grass in the back? the grass on the left is yellow, the other orange?...very frustrating, i'm backing off of it for now...haven't even gotten to the cloning part yet :(
while getting the colours to match, if you're having problems because you can get one set to match but not the other on the same pic (like sky vs. sheds), look into try the history brush. -right below the regular brush, has a little swirl on it- what this'll do is paint what was 'once there', by selecting which step in the files history to paint from. If you can get one set of colours right once, and then get the other set right on the second try, select the older state in the history (there's a little empty icon next to each state), and "paint" over the area that you want to revert backwards... sounds complicated, but its an incredible tool. and if that isn't the case, well, heh, I dunno, just takin a guess is all. also, use all the tools if you aren't meaning the colour balance, curves, contrast, levels and saturation, all found in image-> adjust.
