Sat, Nov 30, 11:32 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Backface only?
Idol ( ) posted Thu, 04 May 2000 at 5:32 PM · edited Wed, 27 November 2024 at 6:08 PM
Hi! I can only se the backface of my new figure I have created. It is exported as an .obj from 3DSMAX and made to a posable figure in Poser. But, the texture seems to be wrong (in 3DSMAX its 2-sided) so I can only se the backside of my figure. It's appear inside-out, like if the front of the figure was transparent or something. Do anybody have a solution to this?
Kevin ( ) posted Thu, 04 May 2000 at 9:19 PM
Maybe the normals are wrong? Does it look right when rendered?
Idol ( ) posted Fri, 05 May 2000 at 1:59 AM
Yes, it's right when I render it. I put this question at the Poser forum as well and I the problems seems to be solved now.
Kevin ( ) posted Fri, 05 May 2000 at 6:11 PM
Ok, good. Sounded like the normals were backwards, as poser renders 2 sided but only displays in preview one sided.
