Thu, Nov 14, 8:17 PM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Very Very ... newbish question ...How do I render in very hi res?
rinaz ( ) posted Fri, 31 January 2003 at 1:54 AM ยท edited Thu, 14 November 2024 at 5:26 PM
Hi,
I'm pretty new at vue, so forgive me for my newbishness. But could someone help me in how to render my image so that it could be higher resolution.
Every time when I export my image, it would be the default 1280 by 1024 px (my screen size)
But I would like for it to be a little larger so I can edit the figures in it without it being ultra pixalated when I enlarge it.
Could someone help? Thanks alot in advance :)
MightyPete ( ) posted Fri, 31 January 2003 at 2:22 AM
Well you cannot render in Vue larger than you screen size. You have to render bigger pictures to disk. Ok click on picture up at the top of the screen then select render options. From there select render to disk then select free from the dropdown on the right then type in the value that you want to render to and render away. You also have to name your rendered picture and save it sort of as the type you want to save it as like bmp for instance before you start ok? Page 102 of the book
rinaz ( ) posted Fri, 31 January 2003 at 2:46 AM
Ah ... thank you very very very much :)
