Tue, Nov 26, 12:54 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: M2 Angel Genitals' Awful Soul Loin Trouble, Much Nudity...
cainbrogan ( ) posted Wed, 29 January 2003 at 6:42 PM ยท edited Tue, 26 November 2024 at 12:53 PM
Hi Folks, Here we have my M2 Angel WIP, with Awful Soul's Free Loin Cloth positioned and almost ready for parenting and/or collision detection! The obvious trouble is that his genitals protrude the front surface of the loin...
cainbrogan ( ) posted Wed, 29 January 2003 at 6:45 PM
But now look what happens when the genitalia is unchecked form the Figure menu! It kinda makes me wonder if this is where the Loin should be positioned, but I still would'nt think that would avoid this obstacle %100. = )
Lucy_Fur ( ) posted Wed, 29 January 2003 at 6:45 PM
Why don't you just turn his genitals off??
Lucy_Fur ( ) posted Wed, 29 January 2003 at 6:50 PM
oops L cross-post I thought Loincloth was created for Vicky - even so, I had to work to make it fit her because I gave her muscular thighs as well. Is Michael's 'nogen' hips a different obj? 'Cause I can see them sticking out in a bit of a 'love handle' way - but they didn't in the first image. I tend to make the dangly things invisible so I don't have to worry about them getting stuck in the character.
cainbrogan ( ) posted Wed, 29 January 2003 at 9:34 PM
So, I turned off the genitals, repositioned the loin, turned them back on and then set several of the genital parameters to negative value. Hey do you think that is was made for V2 has any real differance. It is shaped just like M2's Hip and fits pretty well, if you ask me! Now I'm off to look around for Cloth Room Tuts,., and change the loin MATs. = )
bloodsong ( ) posted Thu, 30 January 2003 at 4:44 PM
heyas; in pic #2, it looks as if maybe you had a full body morph (or several) turned on, but the non-genital hip morphs in that morph set didn't get affected. the hip might snap into shape if you grab it and move it a little. how did you get the loin drape to fit so nicely?? can you make a pose file to position it? i always have trouble getting it to not poke out or get buried in the hips.
cainbrogan ( ) posted Thu, 30 January 2003 at 8:16 PM
Bloodsong - Check your IMs. = )
cainbrogan ( ) posted Fri, 31 January 2003 at 2:25 AM
Loin MAT WIP! How is this scheme coming? Anyone want to see an all white version? How about the belt in yellow? Getting the curves in the cloth whites to appear without being washed out or too gray has taken me all day. I think I'm pretty close though. I managed make a finer linen texture map by loading a regular cloth tex. and then changing its U and V scale to a mear fraction of the origional. This helps bring out the curves alot, but there is still a fine line between gray and washed out. Has anyone a silk or satin texture? = )
cainbrogan ( ) posted Fri, 31 January 2003 at 12:30 PM
M2 and V2 may have must have much the same geometry. I do think it would look really nice with Awful SOul's mgVest, personally, and that is a female article. Thanks for your input! = )
Lucy_Fur ( ) posted Fri, 31 January 2003 at 9:30 PM
cainbrogan - I said I 'thought' it was made for Victoria. ;) Here's a w.i.p. image done almost a year ago w/the character I spoke of in a shorter length - the top is also from Awful Soul.
