Fri, Feb 7, 1:53 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: Tech question about rendering on second computer
skee ( ) posted Fri, 31 January 2003 at 3:03 PM ยท edited Thu, 30 January 2025 at 8:56 PM
I have 2 computers and have networked them together and would like to use one as a render machine for poser antimation. Would I have to load every figure,prop,texture,etc. and the full Poser program onto the second computer. Or could I just load the basic Poser(Poser Pro) on it and save the files off as Pz3 files and have it render while I work on the other computer creating? In other words do I need everything on both computers? skee
NOTE: No trees were killed in the sending of this message, but a large
number of electrons were terribly inconvenienced.
lalverson ( ) posted Fri, 31 January 2003 at 3:14 PM
Yes, Including two registered copies of poser. For if you don'[t, only one will run poser at one time.
skee ( ) posted Fri, 31 January 2003 at 3:26 PM
Thanks ,I had not thought about that part. skee
skee ( ) posted Fri, 31 January 2003 at 3:38 PM
What if I have Poser4 pro on one computer and Poser5 on the other? Would that work? skee
Little_Dragon ( ) posted Fri, 31 January 2003 at 3:57 PM
That's a good question. I assume that each would check for its own version only. Not having a network set up here in the cave, I couldn't say for certain.
praxis22 ( ) posted Fri, 31 January 2003 at 6:32 PM
Or start up on node, download what you need to render then break the link to the network and start up on node two, that would do it. If you have it connected to the network and try to block it's access to same it'll hang. later jb
