Sun, Jan 5, 11:18 PM CST
Forum Moderators: Staff
Subject: Renaming Twist/Bend/Side-Side
bloodsong ( ) posted Sat, 06 May 2000 at 2:59 PM · edited Sun, 05 January 2025 at 10:54 PM
heyas; i was going through the detail gruntwork of setting joint limits and naming the xrot, yrot, zrot dials to real names. but then i came to my senses! in some of my figures, the rotation orders are all (or 90%) the same. so i went through cr2editor and did a search and replace. first, i changed the hip by hand, and saved the cr2. then i searched for zrot, which happened to be the twist axis, and i replaced "name zrot" with "name GetStringRes{1028,2)" (or whatever secret # 'twist' is), which is what comes out in the cr2 if you use a standard poser name like 'twist.' same for the bend and side-side. THEN i saved and opened the search/replaced figure, and what's the name on all the dials? GetStringRes(blahblahblah). now how the heck do you figure that??? sheesh. anyrate, i went through and just changed name zrot to name twist. but it isn't internationally compatible ;) oh, another thing! if i change the order of the rotatey rotatex rotatez things in the cr2, just to change the order of the dials when you use poser, will that screw up the cr2 for 'knowing' which one is the twist?
daveH ( ) posted Sun, 07 May 2000 at 1:02 AM
the operative term in the "name getStringRes(n,n)" command is the second numberical term, which identifies the label for the parameter dial. the code is below. (at least for the numbers poser currently uses; i don't know if there are more.) 2 = "twist" 3 = "side-side" 4 = "bend" 24 = "front-back" 53 = "up-down" for example, the xrot, yrot, zrot labels for the abdomen are as follows: xrot -- name getStringRes(1028,4) "bend" yrot -- name getStringRes(1028,2) "twist" zrot -- name getStringRes(1028,3) "side-side" for the shoulders, which uses both different rotation orders & labels: xrot -- name getStringRes(1028,2) "twist" yrot -- name getStringRes(1028,24) "front-back" zrot -- name getStringRes(1028,3) "bend" in order to completely hide a rotation control (you'll note the eyes only have 2 axes, not 3), change the "hidden" command parameter from 0 (the default value) to 1. this command usually follows the "name" command a few lines down. i've tried using global replace to rename the dial labels, but it can be tricky, esp. after making a mistake; you can't simply replace all the "1028,2" occurrences since you won't be able to globally distinguish the correct ones from the incorrect ones. in the end, some manual hunting & replacing is always required. as for your last question, none of the body parts nor their subroutines need appear in any particular order, as long as all the abdomen routines are properly nested under "actor abdomen", etc., and all the relevant ones are present.
Kevin ( ) posted Sun, 07 May 2000 at 8:35 AM
The GetStringRes bit is a call into the RSR or data segment that replaces the number with the name. Meta uses codewarrior to set this up, so they don't have list either. Odd and strange things can happen if you try to rearrange dials. Morph targets can be done however you want, but it appears that a lot of the dials are dependent in some fashion on earlier dials. So you can rearrange them but the figure might break. Always test a copy.
ScottA ( ) posted Sun, 07 May 2000 at 3:17 PM
If you re-arrange the orders in the cr2. The rotation order is changed to match it. That's how I know what rotation order is used. I look at the order of the dials. There is no way to change the location of the dials and keep the rotation orders where they are at. The rotation order in the .cr2 determines the location of the dials. ScottA
bloodsong ( ) posted Mon, 08 May 2000 at 7:04 PM
heyas; dave; i was using the right numbers, they just... didn't translate. :🤷: oh well. scott: um... hmm. i thought there was another tag that told the twist section that it was a twist, and the bend it was a bend. in the phi, the order defines twist/bend/bend, but... oh well, the less i mess with things the better, right? :) thanks guys!
daveH ( ) posted Mon, 08 May 2000 at 11:37 PM
i notice in your original message you wrote the function call as "name GetStringRes{1028,2)" in which you substitute the first parenthesis with a curly bracket. perhaps this ... ?
bloodsong ( ) posted Tue, 09 May 2000 at 6:07 PM
heya; no, dave, i copied (as text) and pasted it from the one that poser changed itself, to the search/replace slots. try it, see if you can get it to work. :)
