Render times are cpu dependent unless you have to start hitting your hard drive cos the file is too big. So, the more ram will allow you to work more easily with larger files and may help in render times for larger files. (As Erlik said in many less words). I did the 128->320 jump and things got much friendlier all round for me.
Digital
WasteLanD
Be careful if you happen to run Win '98. It's not known for being able to handle higher memory very well. I had 256 Mb and it was less stable than with 128 Mb... I decided I wanted more and used plugged in another 512 Mb and I had to reboot about every other 5 minutes. Installed XP and everything's really fine.
For most versions of Windows (all but the oldest), 128MB just isn't enough. Too much swapping to the hard drive. 384 will help everything run much smoother and faster, though rendering may not increase much in speed (if your files are small).
Be careful with the purchase however. If the motherboard is old, say, less than a 700mhz P3, it may not support 'high-density' SDRAM memory. The older motherboards recognize low-density (128mb and below), but not all understand the high-density, which are all of the 512mb chips and a good percentage of the 256. If you are running a newer machine than that, it should work.
After installing the memory and rebooting, your system should see the increase immediately. Before opening up critical files (and possibly corrupting them if the computer blue-screens), open lots of other programs and switch between them rapidly, over and over, possibly even leaving the system on for a day or so. If the new memory isn't stable in your system you may have spontaneous reboots.
Good luck, once you are running 384 you will never want to touch a 128 machine again.
Ryan
Hi all,
I've just found a 256 module at a reasonable price for my Dell laptop (90 euros). But, nonetheless, it's an amount of money that will bring some difficulties to me, so I was wondering: for your knowledge, upgrading from 128 to 384 is worth it? I'll see some results in render times and management of large files?
I'm willing to upgrade, but I'd love to read what all you people already know about it, so I can make a decision.
Many thanx,
Stefano
