Assuming that the morphs have the same internal (not just dial) names, you can copy/paste the values from one to the other. Select the body part, Edit/Copy or Control/Command-C, then select the opposite body part and paste. You may have to change the sign of some values positive to negative or vice-versa, and some degrees of rotation might need to be mirrored. HTH, Elisa/gryffnn
I'm working on M2, V2 and Stephanie, nudging each parameter dial a bit at a time. This is fun, but I ca'nt understand why, after I've spent an hour on a body part, I ca'nt set the opposite body part to just mirror the new settings? = )
